hello, i retrofitted webasto on my octavia 3 rs tsi, but i coded in bcm anti-theft - parking heater, when i enable parking heater via remote control morning, webasto start after 1min car alarm, car alarm is from factory, need upgrade dwa parameter? OR? PLEASE ANY1 HELP ME? thank you ![]()
Webasto retrofit
Only changing this one adaption channel will not activate the aux heater correctly. Additionally...
Stg 08
Coding
Byte 05 > Bit 4-7 = $40
Byte 06 > Bit 0-3 = $01Stg 18
Coding
Byte 00 > Bit 4-5 = $10Stg 19
Coding
Byte 13 > Bit 2 = enableAdaption
IDE10748-MAS11263 = activeStg 5F
Adaption
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating = active
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high = active
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03 = active
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus = Databus ComfortAfterwards you need to perform Climatronic button combinations:
- press for 5 seconds: AC + Blower: Head
- wait till done
- press for 5 seconds: AC + Read window heater
- wait till doneClear fault codes.
Stg 18
Basic setting
IDE00898 = run (at least 30 seconds)
IDE06639 or IDE06638 = run
IDE06650 = run -- press OFF on the sender
