Upgrading from 4k PDC to 8k 2018 vrs tdi
  • Looking for advice on 8k PDC (not with PLA) I have fit the sensors (4) in the front bumper. Run the loom as required. Fitted the switch in the console and run the wires to the appropriate pins as per Erwin wiring diagram for my chassis number to the 26 pin connector for the pdc module. My current pdc module is 5qa 919283 B (4k). Do I just copy the long coding from my 4k module to the 8k one?
    I have purchased a used PDC module 5qa 919294B do I need to have the data reflashed/ reprogrammed as its come from a VW passat with epb? As when scanned one of the fault codes is for epb?
