Hi all !
Where can i go to upgrade to the digital display ? ik have a Skoda octavia RS245 from 2018 with the MIB2 columbus.
Greets Tuner111
Beiträge von Tuner111
a time ago i have seen it on superskoda indeed.. bud now its gone..
Hellow all ,
I am looking for the cup spoiler / wing for my octavia. anyone have an idea where I can find these?
Thanks, tuner111
you must hear it immediately
Hey everybody!
I have a question. will these wheels be suitable for my O3FL?
Superturismo Evoluzione 19x8.5 ET44 with 235/35/19 michlin 4ps tires.
Thanks!
anyone have the ego x installed on a 245?
Ok, thanks.
I ask because FOX says that the FOX MSD isn´t compatible with the original Skoda exhaust-system.You must order a 60mm To 62,5 to fit..
Yes only changed the mid silencer with the fox one
From where do you get your 12V energie? From the trunklight?Yes indeed like the manual it says..
Hey all !
I have a small problem with my exhaust.. if the valves are open sometimes they open/close for a second or 10 (see video) anyone have this issue ?
Skoda Octavia RS 245 - Cold start - Remus exhaust - YouTube
Hear good on the background..
Greets Tuner111
[Quote = 'Boomah', 'http: //octavia-rs.com/index.php/thread/26767-tuner-s-skoda-octavia-rs-245-berline-octavius-rsus-ii/ postId = 546.821? # post546821 '] Klinkt niet slecht. <img src = "http://octavia-rs.com/wcf/images/smilies/smile.png" alt = ":)" /> [/ quote]
thanks
Inside sound clip
And how is the Quality from this parts? How Long time is the Installation?
Thanks in advance.
The quality is good and the install takes max 5 min super easy
sorry for the late reply..
That’s the one being sold by superskoda, right? Or did you possibly find an alternative?
Yes is the superskoda one.
thanks !
[Quote = 'Light Blue', 'http: //octavia-rs.com/index.php/thread/26309-hellblau-s-rs245/ postId = 540.869 # post540869'] Vandaag was ik in staat om de tijd van de nieuwe A6 TFSI 55 Kijk. De ingebouwde techniek bevalt zeer goed. Wat je daar kunt stoppen. Madness. De Ambientebeleuchtung vind ik geweldig.
De auto heeft 340 pk en 500 NM. Een beetje rijden op ... [/ quote]Nice
do you have a dyno roll sheet ?
Heeft iemand de RS 245 DSG met een HJS-downpipe? Zo ja, "scheet" hij als hij overschakelt? of wat klonk ze technisch in het algemeen? : Thumbup:
I have the downpipe and the remus exhaust. wen you switch gears manual you will here farts.. but you have to work to get them
Sound Without a HJS Downpipe On a rs245 and remus catback
Sound With a HJS Downpipe On a rs245 and remus catback
[Quote = 'Light Blue', 'http: //octavia-rs.com/index.php/thread/26309-hellblau-s-rs245/ postId = 539.903 # post539903'] <a href = "http: // octavia -rs.com/index.php/user/18832-tuner111/"> Tuner111 </a>
ik hou echt van de valpijp mod. Het geluid is beter geworden. Hij klinkt nu pittiger. Je kunt de uitlaat meer horen. [/ Quote]
Thanks for the info !saterday my dp is going under my car
(YouTube)
(/ YouTube)
Next Mod :
HJS Downpipe
WVR Intake hose -
[Quote = 'Street Fighter', 'http: //octavia-rs.com/index.php/thread/24130-remus-cat-back-mit-klappe-und-eg-genehmigung-fuer-den-rs-230/ ? postID = 537825 # post537825 '] de remus downpipe is zonder ECE !!! en ik denk dat de 245 fouten kan maken in ecu als er maar 1 kat !!
dan remus kun je bij mij bestellen voor dezelfde prijs
mail me [/ quote]than i will go for the hjs one
i have sent you a pm
It's better to write in English. Especially the second bullet item is German nonsense <img src="http://octavia-rs.com/wcf/images/smilies/wink.png" alt=";)" />
ok
Hello all!I would like to place the kw ddc kit on my RS 245 with dcc. but I still ask a few things ..
1. Does comfort remain comfort?
2. Is the sport mode louder than the Orphan DCC? and then less role?
3. Are there any drawbacks to this set?
4. Are there other options?Greetings Bram
ps translates from Dutch into Google Translate -
Hey alle zusammen!
ich würde gerne das kw ddc kit auf meine rs 245 mit dcc setzen. aber ich frage noch ein paar Dinge ..
1. Bleibt Komfort Komfort?
2. Wird der Sportmodus auch lauter als beim Orphan DCC? und dann weniger Rolle?
3. Gibt es irgendwelche Nachteile für dieses Set?
4. Gibt es andere Möglichkeiten?Grüße Bram
ps übersetzt mit Google Translate aus dem Niederländischen -
[Quote = 'Street Fighter', 'http: //octavia-rs.com/index.php/thread/24130-remus-cat-back-mit-klappe-und-eg-genehmigung-fuer-den-rs-230/ ? postID = 537463 # post537463 '] volgorde voor de eerste alleen de downpipe. controleer dan onder de RS welke adapter je 100% nodig hebt !!
in de remus zit een ring van 65 mm.
maar ik weet dat dit een beetje moet snijden van de downpipe en weinig van remus.
downpipe kan ... [/ quote]maybe i can buy this one from remus : Remus Edelstahl Ø70mm Downpipe mit 200-Zeller Sport-Kat Skoda Octavia RS Typ 5E Limo u. Combi günstig online kaufen - Dein-Sportauspuff.de ? cheaper and no mods need to be done ?
brauchst adapter von 76 auf 70mm - gibt es - musst dann das remusrohr etwas kürzen und evtl das downpiperohr auch - wegen downpipe darfst dich gern bei mir nochmal melden
Thanks !
next upgrade on the list is the downpipe
found a adapter alsow : HJS Edelstahl Adapter /Reduzierung mit Schellen von 76 auf 70mm, 90605735, Doppelmuffe | Reduzierungen | Zubehör | Abgasanlagen | Abgastechnik | TurboPerformance Shop -
Hallo alle zusammen,
Ich habe eine Frage, ich habe jetzt den Remus-Auspuff installiert, aber ich möchte auch meinen Downpipe mit dem von hjs aufwerten. (http://dein-sportauspuff.de/hj…avia-rs--245-typ-5e-face- lift.html) die Bremse ist Ø70mm und die hjs Ø76mm welche Kupplung würde gut sein? und ist es ratsam, dies zu aktualisieren?
Ich übersetzte dies mit Google Übersetzer so leid für die Fehler: D
Geht Bram
here my s8+ wont fit the phone box
Remus Exhaust on a rs 245
